40-150 push button light
When I recapped my 40-150 years ago I put a home-made felt strip behind the translucent push-buttons to limit the amount of light from the dial lamp coming around them, like similar strips in the 1941 radios. But (duh!) it also limits the amount of light going through the red translucent buttons.
Now that I have the chassis out for other reasons, I wonder: did Philco use another way to limit the white light leaking around these translucent buttons? Are there other ways restorers have devised to cut down on such light leakage while still allowing light to go through the buttons?
John Honeycutt
A Marconi model 86
I have recapped this large Marconi model 86.  It plays quit good.         I have stripped the cabinet and using Mohawk...Dan Walker — 12:18 AM
Table radio 51C or 52C?
I think what you may have is another Phactory Phranken Philco, if the holes in the front panel lined up it was not unusu...Arran — 10:41 PM
Ho OSanders, Sorry, I got really busy in May and haven't seen your thread in a while.  I am VERY sorry about that.  ...MrFixr55 — 10:30 PM
Philco 45L Initial Check Up
Dan; I don't think that the model 45 is especially know for coil problems, not that they can't occur for one reason o...Arran — 10:19 PM
Yes, the end with the groove is positive, the stripe with the arrows points to the negative lead. The arrows have minus ...RodB — 09:36 PM
Thank you Rod and Paul I took a break, did some yard work and Rod "Therefore, it appears cap 40 is connected backw...osanders0311 — 06:35 PM
Hello, I am in the process of checking out a Philco 45L. My question is does this model suffer from the Philco coil r...dconant — 06:11 PM
Purchased a table radio at auction, not because I had to have it, but because no one else bid on it.  $5  Unable to fi...antiqueradionut — 05:14 PM
The 2 towns you mentioned "Frustrated" and "Give Up" are places we have all been. Relax, take 5, thi...Paul Philco322 — 03:23 PM
Philco 89 Code 123 Osc Coil
Thanks for posting that information!klondike98 — 03:14 PM
