Odd 41-220CI
In the Gallery. Look at the dial. Sez Police but coverage is SW. Looks like someone goof in the photo lab.
That's a Philco factory illustration, and yes, they goofed...the set does not have a 9 to 12 mc SW band, but a 1.6 to 3.3 mc band as illustrated in the 41-220C photo just above the 41-220CI illustration.
Good eye, thanks for catching that - I must confess that I had not noticed that previously.
Bob, this is the wrong sequence to look for problems and setup circuits. Always start checking the signal path from the...Vlad95 — 12:19 PM
Philco J1720 stereo and record player with reverb
The above link takes you to the Delaware Valley Historic Radio club. They are not too far from you and may have sugg...klondike98 — 11:49 AM
Tucker Movie Prop car
Richard: Did you ever check with your friend? About once a year I try to verify if Mr Rhoades really worked on the r...WrenchMonkey — 09:22 AM
>>when turning the knobs This is very broad. There are knobs for tuning and knobs for volume, and possibly f...morzh — 07:36 AM
Thx Arran, I will check the antenna connections. Right now the loop is alligator clip connected to the chassis since you...klondike98 — 03:58 AM
Bob; I was just thinking that maybe the 1R5 tube doesn't like being operated at 1.2 volts on the filament, though you...Arran — 12:56 AM
So I just purchased a Philco J1720 stereo and record player. That has some static when turning the knobs. Wanted to see ...PhilcoJ1720 — 12:26 AM
I've started looking into the very weak and garbled reception in the set (I have the HS-62A version of the chassis seen ...klondike98 — 12:00 AM
A Marconi model 86
Those last photos were not very good,so I  used one of my other cameras. This is more like the true colors of the radio....Dan Walker — 10:48 PM
If you look closely at the paper wax capacitors they probably have something like "outside foil" near the blac...RodB — 10:41 PM
There are currently 1228 online users. [Complete List]
» 1 Member(s) | 1227 Guest(s)
