Did the 38-3 have an antenna?
I am wrapping up work on the chassis in my 38-3, and am turning to the cabinet. Mine is in rough shape, possibly having sat in a wet basement: Photo
The chassis has three terminals marked red, black and gnd. Was there an antenna in the cabinet, or was it sold seperately?
Hi Jon
This set was designed for an external antenna; specifically, the Philco High Efficiency Aerial. Any longwire antenna may also be used by connecting it to the terminal in back marked RED. With a simple longwire, there should be a jumper connected between the BLK and GND terminals.
Jon Scaptura Wrote:I am wrapping up work on the chassis in my 38-3, and am turning to the cabinet. Mine is in rough shape, possibly having sat in a wet basement: Photo
I had one of these sets as well. No internal antenna, however the previous owner, an old engineer with WGN Radio in Chicago, custom built a loop that surrounded the bottom of the cabinet. It looked and worked quite well. If I still have photos of the set I'll post so you can get an idea, maybe build your own.
73 de,
Gary/N9VU
Sometimes you will see people run a wire around the back of the frame, I have seen that quite a few times on my 38 models radios. For what they are they seem to pick up local and mid-distance stations decently.
49Stude63 Wrote:Sometimes you will see people run a wire around the back of the frame, I have seen that quite a few times on my 38 models radios. For what they are they seem to pick up local and mid-distance stations decently.
Thanks for the info, guys. I've been using a short length of wire as an indoor antenna. Will a loop antenna work with this set?
I have had success adding loop antennas on many older radios to receive the local stations only. I always keep a good stock of scavaged loop antennas from garage-sale $1 bargain late 50s-60s tube radios that also yield a few good small size pm spkrs and miniature tubes as well. The best way to find out if a loop antenna will work with the older radios is by experimenting with a few different ones, and by rotating them in different directions using only one connector from the loop antenna jump-wired into the main orig outdoor longwire antenna terminal on chassis of the vintage radio. Do not use the other antenna terminal back to chassis ground! That 2nd terminal on the modern loop antenna can be used to continue thru a .00025 mmf cap to your "added-isolated" fahnstock clip mounted somewhere inside the wood cabinet, or special built rear perforated rear radio panel isolated from the chassis, and a regular outdoor longwire antenna can also be attached with the modern loop in series by connection of the 2nd terminal of the modern loop type antenna. The .00025 mmf cap will help keep "antenna -overload" from happening in association with outdoor longwire also being added, but you may want to experiment with several different values mmf caps for best "balance" of the orig chassis tuned circuitry. The modern loop "added" will provide local reception only on the BC band, and if separate antenna terminals are provided for BC/Shortwave reception, always use your outdoor longwire for SW reception separate from BC antenna. Has worked for me before very well. Randal (TxRockr) Icon_biggrin
How does this radio perform? The reason I ask is there is a fairly nice one in an antique store (overpriced, of course - but LOCAL). I was curious what "magnetic tuning" was so I looked up the schematic (looks like it is just some sort of AFC, like in some high-end Zeniths).
But what was curious was that Philco would go to the trouble to implement AFC, and then use some sort of strange method of implementing push-pull audio by driving the grid of one push-pull tube from the screen of the other tube! How could that possibly work (well, at least). Surely adding a phase inverter tube would not cost that much. So I am curious as to how this radio sounds.
It was also not obvious in the antique store how this radio is tuned. There seemed to be some sort of crank arrancement.
davemc Wrote:How does this radio perform? The reason I ask is there is a fairly nice one in an antique store (overpriced, of course - but LOCAL). I was curious what "magnetic tuning" was so I looked up the schematic (looks like it is just some sort of AFC, like in some high-end Zeniths).
My radio performs pretty well after I replaced the caps and a weak tube. I have not attempted to align the magnetic tuning, and notice no difference with it on or off, except for the additional dial lights that come on. As for tuning, the "crank" is used for tuning the presets. The regular tining is via the vernier dial.
Hello PHORUM members, I am still working on restoration of my PHILCO 37-640.  I want to start with rewiring the IF ca...georgetownjohn — 06:32 PM
Gilfillan Brothers Car Radio?
There is a Mission Bell model 19/19A that could be what you’re looking for, Riders vol 4. It has the tube line-up of: 0Z...Joe Rossi — 05:01 PM
Looking for verification of correct schematic.
Definitely 870044RossH — 01:12 PM
12' Philco
Wonder if the chassis was big too.daveone23 — 12:38 PM
Philco 38-2 Automatic Tuning
Hi Ron, I have sent Radio Daze my concerns with the dial so I guess we will see. They used my original to make the repro...dconant — 12:27 PM
Hickok AC51 tube tester
How does the  5W4 and 83 tube filaments get fed?martinj — 12:25 PM
462ron
Hi Dan, your original dial appears to be lighter, easier to allow light through. My original is similar except it’s crac...462ron — 12:07 PM
I received my new 38-2 dial. I'm a little disappointed. As you can see in the picture the blues have a white shadow. The...dconant — 11:13 AM
Philco 38-2 Low Volume
I have been playing my 38-2 for a while now and it is doing very well. I did have to replace the 6A8 (osc) as it develop...dconant — 11:03 AM
Philco Speaker Spider
Hello, Does anyone with a 3 D printer make the spiders for those old Philco speakers? That might be a good idea for some...dconant — 09:41 AM
There are currently 2946 online users. [Complete List]
» 2 Member(s) | 2944 Guest(s)
