RCA 85T ??
I have an RCA 85T, I'v recapped all the paper Caps, I used 10 Mfd Electrol. for C 18 C19 and C20 (was 8, 5, and 5) No static but when I tune 89 and higher on the dial the volume drops considerabilly. All stations track there place on the dial. do i have an A.V.C. problem ? or something else ? can any one steer me in the correct direction ?
b.t.w. I replaced the power Transformer, it was leaking wax.
Thank you for any and all help !
Jack
Check your alignment instructions and see if there is an adjustment for the high-end of the band.
Looking at the schematic, looks like this would be C1.
Also check your 6A7 tube. I've seen too many recently with the weak pentode section, and in this radio where it is both mix/osc and 1st RF it may be critical.
The tube should be at least 800 (the chart gives 1000) on the pentode and above 150 on the osc.
Thanks TA, morzh's
I touched up the Alignment(C1, C5) it helped somewhat.
I will get another 6A7 to try.
Thanks again Both of you
Jack
Jack
Make sure you DO know your 6A7 is good.
I had weird experience with them just a month ago (I needed to check the theory that my 6A7 was not oscillating properly below 6MHz, my FB band did not work there at all) where I bought an NOS tube from a guy (and he was an honest guy) and it tested about 600 instead of 1000, which is "?" territory. I was able to prove the theory (the oscillator worked as it should) but the tube was weak. That was #1.
Then I bought another NOS tube from another guy and it was near-dead, at 300. The guy admitted he did not test the tube as his tester does not test them, and sent me another RCA NOS one and that one was just fine (that's the one I keep in the radio). That was #2.
But before this guy had a chance to react I bought the third tube, also NOS and this time the guy claimed he tested it and it was like 150% or so (not sure what that means).
The tube came, and again, the pentode section was extremely weak. I suspect he tested only the oscillation section (in all three tubes it was indeed very strong).
So, out of four tubes and from three sellers only one was testing properly.
So make sure you buy from someone who tested it on a mutual conductance tester that tests both parts, the oscillator and the pentode, and both are close to new value or at least show strong "good". Ask the seller about how he tested them.
Or go to one of the sources folks here recommend (Bob Dobush at findatube.com).
There are currently 1105 online users. [Complete List]
» 1 Member(s) | 1104 Guest(s)
