Dial Apart on 34
Hi All;
I have downloaded The information on Dial and replacing the Rubber "O" rings, but I am not that far along.. I want to get the Dial face off, so I don't break or crack it..
Also I see that ther are three soldered screws under the Chassis for the Variable Capacitor, and Four screws for the mechanical gearing mechanism.. What all needs to come off and is it in any order or preference ?? and I need to take off the Vairable Capacitor to get at all of the Rust on the top of the chassis.. I would love to take the coil cans off as well, but I don't think they come off.. Am I right about that ?? The top of the Chassis has some deep rust stains in many places on the top of it..
Also, I did order the Tubes that I need.. Two of each, type..
THANK YOU Marty
Hi All;
I found out that the plastic dial face doesn't twist off like the other Dial faces, but it has two set screws that I did not see.. They were hidden from my sight, when I looked at it, they revealed themselves after taking off the front four screws and turning the Dial..
I now have the Variable Capacitor off and can clean the top of the chassis..
I also found out that the top of the IF cans can indeed come off from the top, as it has a large "C" clip holding it on..
Can it safely be taken off and still put back on and hold the can in place ??
THANK YOU Marty
Rogers Majestic R-646
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
Vlad; I looks like your set has the same problem that mine did, both a bad output transformer, and a bad audio inters...Arran — 03:21 PM
Ouch! Not often the secondary takes a hit. Wish there was a better solution. I have a good interstage transformer but it...RodB — 02:59 PM
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
There are currently 1004 online users. [Complete List]
» 2 Member(s) | 1002 Guest(s)
