need help identifying a radio
i have kind of been trying to identify this Philco radio. i think it is a 33 or 34 but am not quite sure. i also wouldn't mind knowing what others think it is worth as it sits.
[Image: https://lh5.googleusercontent.com/-vOeiF...AG0981.jpg]
[Image: https://lh6.googleusercontent.com/-lkxFu...AG0982.jpg]
[Image: https://lh6.googleusercontent.com/-F6GWD...AG0983.jpg]
[Image: https://lh6.googleusercontent.com/-mode_...AG0986.jpg]
[Image: https://lh6.googleusercontent.com/-Z-g46...AG0984.jpg]
[Image: https://lh5.googleusercontent.com/-_Bb0k...AG0989.jpg]
i plugged it in and you could see the 2 tubes start to glow and one of the tubes inside one of the metal things started to glow. speaker also was humming.
[Image: https://lh6.googleusercontent.com/-6LP_H...AG0992.jpg]
[Image: https://lh3.googleusercontent.com/-126cK...AG0990.jpg]
Yours looks to be a Canadian 1933 Model 319A which is equivalent to a USA 1933 Model 19L ( see: http://www.philcoradio.com/gallery/1933d.htm and http://www.philcoradio.com/world/images/canindex.pdf ) Don't plug it in again until the capacitors have been replaced, it could damage some of the components.
thanks. i don't think i would really want to plug it in again. i know i won't be replacing the capacitors. i would rather leave it to someone who is more capable of doing this stuff. any idea what it might be worth in it's current state?
In it's current condition, I would guess $40 to $75 at the most.
Jon
Hi Crazzywolfie,
You have a 19L that I have never seen anywhere. Notice how it's all cabinet with very little radio inside? The same cabinet was used for a few larger Philco chassis, such as the 14, 16, 17 and 18.
Is there any chance I could get you to send me larger, and better, photos of this radio? Sure, it needs a fair amount of work in its current condition, but it needs to be documented, and I would really like to be able to show photos of an actual set instead of the illustration currently here:
http://www.philcoradio.com/gallery/1933d.htm#f
I will send you an email on this subject with my email address.
By the way, I concur with Philco281989 on the rough value estimate - it may be a rare radio but it is not highly desirable, plus yours does need a fair amount of work.
Thanks in advance!
thanks. i was almost thinking $20 would get rid of it fairly quick. i know my mom doesn't want it kicking around but i hate through stuff out especially when it could possibly make a bit extra money which i could always use.
is any of the picture i took what you are looking for or would you want something more straight on? if not i could try taking some better pictures tomorrow.
More straight on, showing the entire radio, plus 3/4 views from the left and right, and a shot of the back showing the entire back would be perfect. 1000 pixels or more in width; larger is better. I sent you an email with my email address to send the pictures to. Thanks!
Where in Canada are you located roughly speaking?
Orangeville, Ontario.
ok. i will try to get some good pictures of it. my phone is setup to take photos at 2592×1728 pixels so they should be large enough. when i think i have got some good shots i will email them to you.
I appreciate that, thanks very much! Icon_thumbup
In that case I think your original thinking about a price of between $20 and $40 is about right given the condition. From what people have told me there are a lot of console radios in Southern Ontario.
it would not surprise me. there is lots of history in the southern Ontario area.
Hi OSanders. another thing about the loop antenna is that it is directional. Try turning the radio in different direct...MrFixr55 — 09:19 PM
The 630v caps will do just fine. Physical size increases with capacity values and voltage. You don't have to replace 200...RodB — 09:09 PM
Help with Supreme 599
Good catch. The 589 is a better schematic but i dont understand how the voltage goes thru the meter to adj the line volt...daveone23 — 08:17 PM
Arron, Yes, I can see the differences in the interior design, but if you compare the schematics, they look very similar...Vlad95 — 06:57 PM
I am not sure how the loop antenna supposed to work but think I have figured it out. I had one lead on terminal 1 and go...osanders0311 — 06:56 PM
Thx Vlad.klondike98 — 06:54 PM
Rogers Majestic R-646
Hi Arran. I continue to disassemble and I see that the interstage transformer is completely beyond repair. It is placed...Vlad95 — 06:50 PM
Hello Rod " If you're not using the 0.33 mfd 200 volt ones for this project, they are excellent tweeter crossover ...osanders0311 — 06:25 PM
Vlad; My set had the same faults as yours when it was about 30 years younger, so I think that these components are sus...Arran — 05:11 PM
If you're not using the 0.33 mfd 200 volt ones for this project, they are excellent tweeter crossover caps.RodB — 04:56 PM
There are currently 354 online users. [Complete List]
» 2 Member(s) | 352 Guest(s)
