2 new Philcos for the flock
38-8 $5
[Image: http://i191.photobucket.com/albums/z309/...7ea0c3.jpg]
Lowboy with tapestry $12............45s are gone
[Image: http://i191.photobucket.com/albums/z309/...24ade3.jpg]
Nice find DK Icon_thumbup
What great finds DK, could only happen out on that other coast area. Not a chance around here.
Jerry
Very Nice Radios... Icon_clap
The 45s are gone from the second console? Not 71As?
Quote:Not 71As?
Hmm.......don't know, just assumed. Which schematic will I want?
How many tubes does it appear to have? Does it have a metal box at the back of the chassis behind the tuning cap? The gallery say that there were four different chassis offered with that cabinet, a 40, a 76, an 87, and a 95. The 95 had type #45s, and I think the 87 did too, not sure about the 40 and the 76 though.
Quote:Does it have a metal box at the back of the chassis behind the tuning cap?
No.....And it has 45s, and only one is missing! What a great auction. It was some guy's collection of hundreds of radios, parts, test equipment, etc. The Mohawk One Dial was $25 with six good 01As. If you wanted parts sets, you could have filled up a pick-up truck for a few hundred dollars. There must have been 30 Philco cathedrals from great to falling apart; but the tubes were in all of them along with the knobs.
Be careful with that because both #45s and 71As are four pin tubes, and in 1929 Philco used both depending on what chassis you had. I remember that there was a Philco 20 in a local antique shop where someone had fitted a pair of #45s in place of the 71As, they were both burned out needless to say since a 71A has a 5 volt filament.
I could see tube number stamped on the chassis in front of the socket (with the dirt rubbed away and a flashlight in my mouth.)
Hi All;
DK, I hope the end of the flashlight is cherry flavored..
THANK YOU Marty
EdHolland. Glad you liked it. Thanks for the supportRadioSvit — 05:24 PM
Great stuff, Peter thank you for posting.EdHolland — 04:06 PM
My Philco 37-116 Restore
The crack goes from almost the bottom of the tube to well past the fat part. It is an ST type tube. The filament is open...dconant — 10:04 AM
Where is the crack? A cracked tube that has air inside will turn opaque once turned on. Perhaps it is a scratch, nogt a...morzh — 09:50 AM
I found I have a cracked 6J5 (AVC) tube. Since the tube shields are so tight I must have broke the tube putting the shie...dconant — 05:32 PM
Looks like I made a mistake. I painted my tube shields silver. Now the reception is poor and can't really zero in on mos...dconant — 01:10 PM
Need Help to ID this radio 11 tube Philco
I did R73 RCA. It has a phenolic board with all stuff mounted on it. And the wiring is deep under everything including ...morzh — 10:37 AM
48-482 rear panel help
Hi Keith, here is an article that covers different FM detector circuits including a section on the theory and alignment ...462ron — 08:26 AM
462ron
Well then Dan I guess this old man’s memory wasn’t too foggy :lolno: although I couldn’t remember where I saw that upgra...462ron — 08:08 AM
Fortunately, I did not have to do much to my GE S-22 (RCA R7A) Almost all caps and the 2 audio transformers packed into...MrFixr55 — 07:44 AM
There are currently 821 online users. [Complete List]
» 1 Member(s) | 820 Guest(s)
