Model 38-3 Volume Control
I had my model 38-3 radio recapped recently. It plays very well but it seems that there is an issue with the volume control. When I turn the volume control fully counter clockwise to the minimum volume setting the radio does not mute. A few times when I turn the volume clockwise to increase the volume the volume will increase but most of the time the volume actually decreases a bit. This does seem to be intermittent but again most of the time the volume control doesn't adjust the volume level. It seems to remain at a constant level. What should I check to see if I can correct the volume control?
Charlie
Looks like a tapped volume control, might be hard but not impossible to find a direct replacement. I'd try cleaning it with some deoxit, and measuring end to end and with wiper moving resistance with ohm meter, tap included. Work arounds with still obtainable controls can be done.
If the paper capacitors and ancient carbon resistors have been replaced, these should not be an issue.
Let us know.
Kind of blurry schematic here:
No cost version:
http://www.nostalgiaair.org/PagesByModel...013243.pdf
Better one (well worth it!) available at
You posted the same link twice. Bet you meant to send him to either
http://www.antiqueradioschematics.org/about.htm or
Thanks, right on.
Philco model #20
Hi Rick, The volume control on the Model 20 has 2 sections and does 2 seperate things: One part of the control, ...MrFixr55 — 10:30 PM
Philco model #20
Hello again fellows , well I powered up the set this evening after I had changed every cap and resistor in this set and ...onlyrick — 09:34 PM
Yes - better it happened on the repair bench than returning to the owner. The other question is - do I also dissect a...EdHolland — 09:08 PM
That's a bummer but get them now. Paul BPaul Philco322 — 08:27 PM
I completed the insulation on the cabinet interior (Al foil and hi temp silicone rubber), and reglued the speaker gasket...EdHolland — 06:18 PM
Tim - Photos of 8 octal tube sockets. (Top and bottom) Send me a PM if you're interested.RodB — 04:11 PM
VTVM meter moves when my hand is next to it & not on
Haha! I hope so. It seemed rather lost and forgotten languishing in the frozen Northeast of England.EdHolland — 02:36 PM
Ed - it's in the Cayman's enjoying the good life.RodB — 02:14 PM
Static electricity - but the other chaps beat me to it again. I've seen this before with analogue meters. I've also ...EdHolland — 01:56 PM
