Philco 96
Hi Guys,
I have a question about fuses. I would like to place a fuse holder in the chassis of the 96 and was wondering what size fuse and do you prefer standard or slow-blow? Is there a general rule for fuses for all transformer type radios? Thanks much. Bob
Robert Chesarek
Renfrew, PA
Hello Bob, I also fuse many of my vintage radios. I have found that most of the time, a 1-amp fuse is sufficient to operate all my radios after a complete "re-capping" of my radios that have a AC power transformer. I dont fuse any of my ac/dc radios, but use a "safety cap" where applicable on a "live" chassis design.Determining the "surge factor" involved on initial power-up of different types of vintage radios with a AC power transformer will also have a factor in determining the proper amperage of fuse you should use, and if they should be fast or slow blow types used in your model 96 circuitry. I have found that most fully-electronically-restored vintage radio chassis usually draws only about anywhere from 3-tenths to 4-tenths of 1-amp if everything under the chassis is operating correctly. I use the fast-blow type myself because fuses are alot less expensive than replacing any transformers! I will add that I am not familiar with the model 96 chassis, but offering info that I have found always works for me. I have over 100 fully restored vintage radios in my collection, and 1-amp fast-blows are installed in the ones with a ac pwr transformer with no operating problems at all. Randal
Thanks much Randal. I do agree better safe than sorry. This model 96 chassis was only half way done by someone in the past. He rebuilt some blocks but left others alone. I will complete the work now. Thanks again, Bob
Robert Chesarek
Renfrew, PA
Shadow Meter Bulb
Not sure if anyone has tried this but there are 6.3 volt miniature lamps in bayonet and screw-in base options available ...GarySP — 11:31 AM
Shadow Meter Bulb
Any 6.3 volt pilot light will work. I would use the brightest one I could find in my workroom. Be sure the dial is clean...RodB — 10:45 AM
Tim, nice write up and thanks for sharing !! Sincerely Richardradiorich — 02:47 AM
Well, this was a real "Hum-Dinger" :lol: ! This will be kinda long, but hopefully it will help others having t...TV MAN — 01:55 AM
Shadow Meter Bulb
Philco 41-608 changer coupler
12' Philco
12' Philco
Hickok AC51 tube tester
