Truetone
Greetings all:
Would anyone have or know of a manufacturer cross reference for the Trutone sets sold at Western Auto Stores?
I have an early one made by Detrola, it has many clues, I do not know if any one has a list. I am now looking for a manufacturer on a 2622. I think they had several suppliers.Icon_confused
All help appreciated.
Thanks.
Hi Paul,
I have a schematic and service data for a Western Auto model D2622. It doesn't say anything about a manufacturer.
Tubes are 12SA7, 12SK7, 12SQ7, 50L6GT, 35Z5GT.
Not sure if this helps any.
Jim
Paul, you know all about AA5's as you demonstrated last week on the show. Now what is the question?
Hello, Paul: When I restored my D697 I went to the Wells Gardner schematics and found some good stuff.
Since your set is a Detrola, recommend going to the detrola schematics.
Also, try the cross-reference site on the www.gillecloth.com site, it often will help you find what you are looking for.
Thank u all, really nothing but curious who made this puppy. It plays very strong, I got it off a fellow collector. The cabinet is too large really for the AA5 but it is a very solid set. It is aligned right on and is pretty sensitive at nite with just the Stratoscope antenna. it has 3 original tubes and is one of the cleanest chassis of any set I have.
I have heard that a well aligned set can be quite sensitive, perhaps this explains why some 5 tubers are mezza mezza and some seem to outperform their design.
I have seen cross references for makers of Silvertones and thought such a list may exist for Trutone.
Vlad; Yes it's very similar, Motorola obviously wanted to get the most use they could out of the dyes used to stamp o...Arran — 11:18 PM
Rod; I that 27 pf 1 kv capacitor you found a C0G ceramic cap or just a regular ceramic cap? A different topic but I t...Arran — 11:16 PM
Rogers Majestic R-646
Vlad; It's possible that the tar/bitumen using to pot the box may have lead to the failure of the transformer, either...Arran — 10:28 PM
Hi OSanders. another thing about the loop antenna is that it is directional. Try turning the radio in different direct...MrFixr55 — 09:19 PM
The 630v caps will do just fine. Physical size increases with capacity values and voltage. You don't have to replace 200...RodB — 09:09 PM
Help with Supreme 599
Good catch. The 589 is a better schematic but i dont understand how the voltage goes thru the meter to adj the line volt...daveone23 — 08:17 PM
Arron, Yes, I can see the differences in the interior design, but if you compare the schematics, they look very similar...Vlad95 — 06:57 PM
I am not sure how the loop antenna supposed to work but think I have figured it out. I had one lead on terminal 1 and go...osanders0311 — 06:56 PM
Thx Vlad.klondike98 — 06:54 PM
Hi Arran. I continue to disassemble and I see that the interstage transformer is completely beyond repair. It is placed...Vlad95 — 06:50 PM
