SW 03-5S1 @ the Flea Market-Just Couldn't Resist
I must admit it, I'm hooked on vintage radios (as I'm sure many of the Phorum readers are also). Saw this one today at the flea market. Seller wanted $35 but settled on $20. Seems to all be there except for the back and one knob. It's a Stewart Warner model 03-5S1 with the "Magic Keyboard" push button tuning. It's an AM/SW. I believe the back, which is missing, houses the "Magic Antenna". Should be fun to work on. I already located a how-to repair on the "Magic Keyboard". Radio still has original stickers inside!
Craig R.
and more pics.........................
Craig R.
That'll be a good looking radio when you get it done.
Cool looking radio. 20 bucks great deal.
I couldn't find much on this radio but found a link that showed a restored one. I do think it's a cool looking radio. I look forward to working on it. Here is the link:
http://www.renovatedradios.com/articlePages/magic.html
Craig R.
Gotta get a knob. I bet Gobs of Knobs has one.
Thanks, my friend, I will check with them.
Craig R.
The cabinet on your example was finished in a lighter shade then the one seen in the link. Good thing they have details about repairing those canvas strap pushbuttons, you are going to need them.
I'd be lost without that link on push button repair. Interesting concept. Was that method for push button operation very widespread? I would think not.
Craig R.
Philco 40-120C Restoration
Not my radio just trying to help. DavidDavid — 02:48 PM
Philco 91 Restore Code ??
Thanks Rod. Since the screen grid is not tied to the plate then my tubes are pentode right? I see the candohm ties to th...dconant — 02:29 PM
Yes, you can look at the schematic. When the output tube screen grid is connected directly to the plate then it's wired ...RodB — 01:51 PM
Can someone tell me if my 42 tubes are connected triode or pentode in fixed or cathode bias? How could I tell by looking...dconant — 10:47 AM
Hello David, that is great news about the tubes source being local ! Sounds like you got good start on the radio . ...radiorich — 09:41 AM
An attempt to remove the Field Coil from a G speaker
Mike; I've only run into a speaker with an open filed coil twice, and they were on newer speakers from the 1940s. One ...Arran — 12:48 AM
Arran Yes, this is my plan for now and what do I got to lose, this is not even the speaker from this radio, but one o...morzh — 10:44 PM
Mike;  I would unwrap the field coil, and see if maybe there a break near one of the ends, like where the coil wire att...Arran — 10:23 PM
...and this is what I did. I fed a little LT into the screwholes with a small brush, and a little on the rim next to the...morzh — 09:52 PM
I combined the two 40-120C threads together as we like to keep the discussion of the same radio together. It helps with...klondike98 — 09:36 PM
There are currently 2981 online users. [Complete List]
» 1 Member(s) | 2980 Guest(s)
