Chassis support stand
There has been much discussion about supporting a chassis during restoration. Just wanted too offer some pictures of one such stand we just built over the weekend. This can be done many ways but here goes. The stand can be raised to five different heights and rotated 360 degrees so you work on the top or bottom. Any size chassis can be attached depending on your mounting hardware and clamping devices.[Image: http://i1281.photobucket.com/albums/a508...121eb2.jpg] We built two of these for around $30.00 which includes all wood and hardware.
Some more pictures.[Image: http://i1281.photobucket.com/albums/a508...3a7ba8.jpg][Image: http://i1281.photobucket.com/albums/a508...85f77c.jpg]
Nice design with good versatility! Thanks for sharing your idea!
Craig R.
We just completed the restoration of a 37-116 using this stand and it made the handling of this monster so easy and at any angle we wanted it.[Image: http://i1281.photobucket.com/albums/a508...450207.jpg] so I know there are more ideas out there so lets hear about them.
Icon_thumbupIcon_thumbup
Another variant
[Image: https://dl.dropboxusercontent.com/u/54621529/stand1.jpg]
[Image: https://dl.dropboxusercontent.com/u/54621529/stand2.jpg]
Very nice that works for me.
Philco model #20
AHH HA , I got it and can’t thank you fellows enough , when I changed the capacitors I took the advice and did not unsol...onlyrick — 02:24 PM
Hello Ed, yes, I like letting projects run for few days to make sure they don't start acting up . Sincerely Richardradiorich — 01:03 PM
I am almost finished with this restoration. All which remains is the power transformer. I cleaned it up some time ago, b...jrblasde — 12:41 PM
Philco model #20
I seem to recall in some TRF sets there being a Local/Distance toggle switch that removes the B+ from the first 24 rf tu...RodB — 09:46 AM
Refinishing Ideas
Hi Doppelganger, After rereading your thread, did you mount the Zenith speakers in the two bottom left and right pos...MrFixr55 — 09:39 AM
Philco model #20
Hi Rick, One other thing regarding volume on this set.  Make sure that the tube shield is in place.  this is that la...MrFixr55 — 08:22 AM
Philco model #20
Hi Rick, The volume control on the Model 20 has 2 sections and does 2 seperate things: One part of the control, ...MrFixr55 — 10:30 PM
Philco model #20
Hello again fellows , well I powered up the set this evening after I had changed every cap and resistor in this set and ...onlyrick — 09:34 PM
Yes - better it happened on the repair bench than returning to the owner. The other question is - do I also dissect a...EdHolland — 09:08 PM
That's a bummer but get them now. Paul BPaul Philco322 — 08:27 PM
There are currently 891 online users. [Complete List]
» 3 Member(s) | 888 Guest(s)
