Installing Philco 90 dial scale
I cant believe the trouble I am having getting the dial scale on this radio. Ive tried installling the drive mechanism bracket first, then trying to install the dial scale. Even with the bracket slightly loose, I cannot get the metal lip of the scale into the slot in the drive wheel and on the tuner shaft at the same time.
Also tried putting the dial and the drive bracket together first then installing as a unit. Still no dice. With both parts together, I cant get he bushing in the back of the drive bracket into the hole in the plate of the front of the tuning cap.
Same as a 70.
Is there a trick to this???
I figured it out. The two pieces go on as a unit. It takes a bit of pressure to get the metal lip of the scale to separate the two halves of the drive wheel. Loosening up the tuning cap from the chassis helps too.
Now I know!
Ed; One thing that I will say about these is that Brand Z was considerate enough to make these mica caps easily acces...Arran — 02:34 PM
Do you know what run # your chassis is? It took me a while to find what you were basing updates/modification on as I did...Radioroslyn — 07:34 AM
COLLEAGUES, Thank you all for such good and important suggestions as how to find good replacement parts. I will go fo...palonso — 07:05 AM
Here's what the inside of AM IFT2 looked like, and the other pic shows the discs I made to take place of the mica and ke...EdHolland — 07:40 PM
IF2 will need replacement caps. The arcing was severe enough that the mica is pitted and holed where the HT flashed over...EdHolland — 04:04 PM
My Philco 37-116 Restore
Measuring from center tap like the tube voltages show. Cap 127 is isolated from ground. Cap 127 shown in upper left of p...dconant — 08:05 AM
Are you measuring relative to the centertap or the GND?morzh — 11:57 PM
Still not clear on the wiring interface between the 6A7 and oscillator. After refering to the available schematics and s...Tubester — 07:18 PM
Refinishing Ideas
My 37-116 code 121 is the best sounding radio i have...a daily driver. Since we are talking about "changes". ...poulsbobill — 07:18 PM
Hello, I finally got brave enough to take the cans off the Expander Unit. Got the grid cap wires replaced and back toget...dconant — 06:50 PM
There are currently 696 online users. [Complete List]
» 2 Member(s) | 694 Guest(s)
