Resistance Readings for Philco 118
Just acquired a Philco Model 118. (The version with the tombstone cabinet)
The chassis has 8 tubes and shadow meter tuning. It looks like everything is there.
Before I get too deep into this project I want to check all of the coils ,the power transformer, the audio transformer, 1st & 2nd I.F., and any other coil that I failed to mention.
That being said, I am looking on the Rider's schematic (Page 5-36) and I see there is no resistance values given for the parts I want to check.
Does anyone have a schematic or information that shows the proper resistance values?
Hi Kirk
Generally speaking you are looking things that have a pretty low resistances. If you see anything above 5K or so that part may be suspect. Most should be around a few hundred ohms if not lower.
Nice set!! Should be a GREAT player!! I think I've got the modern style console. Haven't fixed her up yet.
GL
schematics
Thank you for the detailed response MrFixr. To clarify, the hum starts when the tubes are fully warmed up, and goes a...sq65 — 09:15 AM
MrFixr The chassis, if there is no ground pin in the AC plug, due to the Y-caps from L/N to the chassis, is at 60VAC re...morzh — 08:47 AM
schematics
thanks I'll try the polar caps seperatelymseno — 07:38 AM
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set warm...MrFixr55 — 12:44 AM
There are currently 750 online users. [Complete List]
» 1 Member(s) | 749 Guest(s)
