KENT 422
I have a Kent 422 ,little metal 4 tube radio ,I 've got it playing,but would like to know if this can be found in "Riders" not a real good preforming set,so far ,has no IF tube? need alinement, IF 455?
I don't see it in Rider Vol 1-23, nor in Beitman. Seems it may be a tough schematic to find; the Radiomuseum is looking for one: http://www.radiomuseum.org/r/kent_422.html
This fellow has one, you might try emailing him: http://web.eecs.umich.edu/~srs/Antiques/
That looks like a re-badged Arvin.
Have a look at this:
http://www.nostalgiaair.org/PagesByModel...012516.pdf
I think this is an Arvin radio, THANKS for the tip on the schematic BRENDA that sure looks like my radio! I got it to play somewhat better got it tracking good ,loose the signal on lower end,mixer/detector problem?
This radio plays like it looks CHEAP! ,I think by using the name KENT they though they could cash in on the ATWATER KENT name ,but AK never built anything this cheap!
In a Russian prison/criminal argot "Kent" means "a pal". Icon_smile
Bill,
These sets are a bit tricky to align properly, and if not done right, you won't have any low end at all.
You pretty much have to ignore the dial calibration on the low end of the dial. Set your signal generator to 600 KHz then find the signal on the radio. Once you find it, you need to tweak the outer rotor plates on the antenna section. By pulling the cutout sections out a bit or pushing them in a bit, you'll change the resonance of the antenna section to bring it into alignment with the LO. Then use the trimmer on the tuner to bring both the LO and Antenna to match the dial at about 1400 KHz. You may have to do this several times.
How did they calibrate it at the factory? Same way?
Hello guy's, Have a Trutone A2-G teledial floor model radio that I am having issues with. Suspecting maybe speaker or ...murf — 03:25 PM
Testin a speaker and output transformer Trutone A2-G
Hello guy's, Have a Trutone A2-G teledial floor model radio that I am having issues with. Suspecting maybe speaker or ...murf — 03:24 PM
Save the money on the Kapton tape. Just cut an insulator to size out of a clear plastic blister pack and attach it arou...GarySP — 01:13 PM
The thing is when I touch or probe the antenna terminal, the volume control input, the wiper (output), and the primary t...Stormlord5500 — 12:53 PM
Two small radios from France. Restoration and review.
Hello, Vlad. I agree with your description of French radios. I might add that they are made like French cars – extravaga...RadioSvit — 11:08 AM
I do thank you all for helping me out on this.Stormlord5500 — 08:01 AM
It does oscillate. Here's the deal. If I touch a probe or my finger to anything in the secondary circuit of the antenna ...Stormlord5500 — 08:00 AM
Hello Arran, Some great info so you are talking about silver migration then that seems to really play issues with these...radiorich — 02:43 AM
Hi Stormlord and welcome to the Phorum. I am scratching my head because, even if the primary of the antenna coil is b...MrFixr55 — 01:56 AM
You do not have to use Kapton: buy a bottle of fabric glue and simply put a thick layer to fix the turns.morzh — 04:04 PM
There are currently 2065 online users. [Complete List]
» 2 Member(s) | 2063 Guest(s)
