Escutcheon pattina ?
I'm trying to remove a white powdery film on a brass escutcheon. I want it to be a rich brown color not bright. Tried vinegar and salt - didn't work. Any ideas ?
I recently read something similar where the part was cleaned with Brasso and then covered with either toning lacquer or a mixture of stain and polurethane to tone down the 'brightness' of the piece. I'll try and find the info and post it here.
If you have to rub the escutcheon to the point that bright brass is revealed to get rid of the white, you can then spray the escutcheon with Extra Dark Walnut or Van Dyke Brown toning lacquer to restore the look of the patina, then polish out the high spots so that only they show through. Finish with clear lacquer to preserve the look. The escutcheons for Models 14, 17, 18, 19, 22L, 23X, 89 and 91 look very well when treated in this fashion.
Thank you for the detailed response MrFixr. To clarify, the hum starts when the tubes are fully warmed up, and goes a...sq65 — 09:15 AM
MrFixr The chassis, if there is no ground pin in the AC plug, due to the Y-caps from L/N to the chassis, is at 60VAC re...morzh — 08:47 AM
schematics
thanks I'll try the polar caps seperatelymseno — 07:38 AM
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set warm...MrFixr55 — 12:44 AM
schematics
I think mseno is talking about cap# 27 which is a multisection but in a paper tube. In cases like that I've usually be ...klondike98 — 11:25 PM
schematics
Ohrenet  :roll: For their price I would chase a fly in a field.  :twisted:Vlad95 — 11:21 PM
A bit more work on the Motorola. I got the repro battery together right up until I realized the snap clips on the top o...klondike98 — 10:45 PM
schematics
Often restuffed. If a twistlock, Hayseed Hamfest makes modern replacements. morzh — 09:18 PM
schematics
Looking for a multi-sectional 8+16 mfd cap. Can't find any suppliers that carry it.mseno — 08:45 PM
There are currently 1244 online users. [Complete List]
» 2 Member(s) | 1242 Guest(s)
