The radio cloth
Hi,
It may be a long shot, but still worth asking.Original cloth is in the very good condition, just weathered. Glued to the plywood removable frame. looks new from the back side. Is there any way to have it removed and flip over? I was thinking to use some steam, perhaps.Have nothing to loose, as I restore the cabinet and will need new look anyway, so if it is damaged- be it, will get the new one, but it is not the same. Any ideas? Thanks.
You can try heating the glued edges with a blow dryer. It may loosen the glue.
If you can get the glue off , that is great but I have not been able to get it all off , ,but as you say ,if it does not work put a new cloth on.
It might be worth a try, depending on how close a pattern you can find if it does not work.
Since then I was able to remove the old fabric twice (table top sets) by gently blotting the edges with a lacquer thinner and pulling them away. The speaker side is usually not weathered and very close in pattern to the face side. I believe it could be reused.
Yes, and if there is enough length and width, the cloth may be moved a bit to displace faded areas. Some cloths were affixed with "water glass" which is soluble in, guess what? A cardboard equivalent replacement substrate can be made with patience. Even a tear or two can be fixed by a sharp eye (certainly no longer mine,) and some thread.
Arran. As always, the information you have provided is very valuable to me. Thank you. Yes, it is a Canadian Philco 316A...RadioSvit — 04:04 PM
Best to use the one from the library on this site, then when you refer to part 30 we know which part you are referring t...RodB — 03:32 PM
52-942
Welcome to the Phorum, Ken! The included schematic for your set is located in the Philco Library at the bottom of our Ho...GarySP — 03:13 PM
Video Source for Predicta
You can also source a used VCR and use that as a modulator to feed your DVD source into.TV MAN — 02:57 PM
52-942
Just received my 52-942. Its a handsome set. When I opened the back to examine it I noticed there are not connecting wir...Ken Arroyo — 02:54 PM
"Your radio tubes get these voltages from the power transformer secondary windings. The A voltage is supplied by th...osanders0311 — 01:40 PM
Please correct me if I am wrong, while working on this radio I noticed under the chassis where the bottom of the tubes p...osanders0311 — 01:28 PM
"BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you rep...osanders0311 — 01:04 PM
BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you replace t...RodB — 11:08 AM
Okey dokey, let's get on the wayback machine. Back when radios were running on batteries, they were powered by three DC ...RodB — 10:34 AM
There are currently 783 online users. [Complete List]
» 1 Member(s) | 782 Guest(s)
