46-1209 if cans
My 46-1209 gets no radio at all on any band. The amp is very strong. My gut is that one of the if cans are bad. I have a donor chassis so is it ok to swap the if from the donor chassis ?
Why do you think the IF transformers are at fault? Did you check the windings for continuity?
How do the operating voltages on the tubes compare to the readings listed on the schematic?
Honestly, there are many things that could cause no reception and a bad IF transformer is probably the last place I would look.
When the radio was working it slowly faded out. I used to adjust the if next to the 7f8 to get it back until that did not work anymore I replaced the 7f8 and both 7h7 but still no luck
Have you changed any of the paper capacitors or power supply electrolytics? Fading out could be caused by high leakage causing the output tubes to draw excessive current.
I would check the power supply voltages and change any critical capacitors before proceeding any further.
I have replaced all the caps
Agree, you might have one or more carbon resistors that have drifted high and may cut out completely when power is applied. Mayn now just replace all of them whilst doing the capacitor replacements. Of course, poking around with a chopstick might discover a mechanical flaw as well. Otherwise work bakwards from the audio to the antenna to find the malfunction.
Here is the service info for your radio:
http://www.nostalgiaair.org/PagesByModel...013586.pdf
There is a chart which gives all the voltage readings for the tube socket pins when the radio is operating properly. Compare these readings to yours to try and localize the problem.
As Codefox said, a bad resistor could cause your symptoms. Voltage checks should point you in the right direction. I would check around the 7F8 tube first.
[split] New member...
You may have to start further back with your signal injection at the IF signal grid, then tune the second IF transformer...RodB — 10:28 AM
Well, with the replacement tuning assembly, I have finally put the unit back together and aligned the dial.  The first s...HowardWoodard — 01:01 AM
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM
There are currently 1012 online users. [Complete List]
» 3 Member(s) | 1009 Guest(s)
