model 71H with code 223 chassis
I have this beautiful highboy here ready to restore after i repaired the antenna coil primary, a quick check of the rest of the coils and all are fine, now ready for some re-capping. looking at the schematics i have downloaded i see that i have an extra cap bank that the schematics do not show, turns out all i can find are schematics for the code 121, and 221. this chassis is indeed a code 223. can anyone steer me in the right direction as to where i can obtain a schematic and service info for this particular chassis?
this is an American model and i live in Canada.
thanks in advance!
Check with Chuck, he will have what your looking for.
http://www.philcorepairbench.com/
Gregb
Ok will try that! Thanks!
[split] New member...
You may have to start further back with your signal injection at the IF signal grid, then tune the second IF transformer...RodB — 10:28 AM
Well, with the replacement tuning assembly, I have finally put the unit back together and aligned the dial.  The first s...HowardWoodard — 01:01 AM
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM
There are currently 1024 online users. [Complete List]
» 3 Member(s) | 1021 Guest(s)
