Zenith 7H822 Dial light?
I have two of these and there is no dial light in either and I can't find one in the schematic. Has anyone ever added one? Is it a good idea to do so?
Here's the schematic
Eric
The Villages, FL
These weren't designed to have a dial light. If you were to add one, it would have to be a 120V type, as there is no rectifier tube from which to tap the voltage for a smaller bulb.
Thanks Brenda, that's kind of what I thought. I'll leave it the way it is.
Eric
The Villages, FL
Take a bright LED about 10mA or so. Take a resistor. Take a diode, some 50V Vr will do. Put them in series acrodd any of the 12V filament of one of the tubes.
The diode and the LED should be plugged with the same poalrity and the resistor should be about 1K to 2K.
Try it see how it works.
PS. Do not extract the tube whose filament you used for the LED while the radio is hot.
Wouldn't even need the diode, Mike. LED's run fine on AC.
Neon pilots complete with mounting stuff and resistor can be had for pennies. Bought a pack years ago and still have some. Use on 120 VAC, no heat, drill one hole and you're set.
Considering the fact that Zenith didn't want to put one in, I'm going to leave it the way it is.
Eric
The Villages, FL
Brenda
It may run fine but it is out of specs. If you have 6 to 12V AC across the LED and it is reversed then you are exceeding the max reverse voltage which for most LED lamps is 4-5V. Hence the diode.
Best to use the one from the library on this site, then when you refer to part 30 we know which part you are referring t...RodB — 03:32 PM
52-942
Welcome to the Phorum, Ken! The included schematic for your set is located in the Philco Library at the bottom of our Ho...GarySP — 03:13 PM
Video Source for Predicta
You can also source a used VCR and use that as a modulator to feed your DVD source into.TV MAN — 02:57 PM
52-942
Just received my 52-942. Its a handsome set. When I opened the back to examine it I noticed there are not connecting wir...Ken Arroyo — 02:54 PM
"Your radio tubes get these voltages from the power transformer secondary windings. The A voltage is supplied by th...osanders0311 — 01:40 PM
Please correct me if I am wrong, while working on this radio I noticed under the chassis where the bottom of the tubes p...osanders0311 — 01:28 PM
"BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you rep...osanders0311 — 01:04 PM
BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you replace t...RodB — 11:08 AM
Okey dokey, let's get on the wayback machine. Back when radios were running on batteries, they were powered by three DC ...RodB — 10:34 AM
Meter is a DMM (Brymen BM-257 to be exact) Voltage being measured to the chassis Yep, just double-checked 'emsq65 — 10:22 AM
