TrueTone D-717 filter cap polarity
The schematic is not marked and someone has been in here before and I want to put things back so.
C11 neg goes to chassis pos to 80 heater
C10 Neg to center tap Pos to 80 heater?? or am I backwards?
http://www.nostalgiaair.org/PagesByModel...023887.pdf
Both correct.
Interesting how the field coil is run on the negative side of the power supply, I haven't seen that before.
Just wired it in they had one wrong, when I first brought the up voltage and when the set was at full voltage it had a loud 60cyc hum but that's all gone now. Thanks
Eric
Sure. Did you replace the one that was wired wrong? Hundreds of volts the wrong way across a cap will likely shorten its life if it isn't already dead.
Best to use the one from the library on this site, then when you refer to part 30 we know which part you are referring t...RodB — 03:32 PM
52-942
Welcome to the Phorum, Ken! The included schematic for your set is located in the Philco Library at the bottom of our Ho...GarySP — 03:13 PM
Video Source for Predicta
You can also source a used VCR and use that as a modulator to feed your DVD source into.TV MAN — 02:57 PM
52-942
Just received my 52-942. Its a handsome set. When I opened the back to examine it I noticed there are not connecting wir...Ken Arroyo — 02:54 PM
"Your radio tubes get these voltages from the power transformer secondary windings. The A voltage is supplied by th...osanders0311 — 01:40 PM
Please correct me if I am wrong, while working on this radio I noticed under the chassis where the bottom of the tubes p...osanders0311 — 01:28 PM
"BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you rep...osanders0311 — 01:04 PM
BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you replace t...RodB — 11:08 AM
Okey dokey, let's get on the wayback machine. Back when radios were running on batteries, they were powered by three DC ...RodB — 10:34 AM
Meter is a DMM (Brymen BM-257 to be exact) Voltage being measured to the chassis Yep, just double-checked 'emsq65 — 10:22 AM
