toner colors
I'm about to finish my 70 cathedral ( mohogany sides & top ) with the toner laquer and was wondering what shade should I get for the top and sides and then also for the front panel? PS ,thanks for your help on my previous post. I now know how to do this, just not what colors look best. Thanks.
I used Behlen Master Jet Spray dark mahogany B101-0831 on a reddish mahogany cabinet with good results to even out the color all around after replacing some damaged veneer. Start with a very light coat from a distance and as you see how it is evening out the color of the cabinet, you can apply more coats. Let the toner dry between coats as the colors look a little different when dry.
Philco 41-608 changer coupler
12' Philco
12' Philco
Hickok AC51 tube tester
Arran If the wire inside cans is the gauges you mentioned, the sole reason for that would be mechanical, to stiffen t...morzh — 12:56 PM
12' Philco
Rod, Yes, I know, but the Giant Philco is not around anymore either, so I go by whoever was alive fairly recently. H...morzh — 12:54 PM
Note that no power cord, power switch, or power transformer switch are shown. That (along with my experience with full s...DaleHCook — 07:09 AM
There are currently 5566 online users. [Complete List]
» 1 Member(s) | 5565 Guest(s)
