How to test an old speaker?
I've got a couple of very old speakers that I would like to test. One is the horn style (I think it is a radiola) and the other is the round kind. I don't have a 1920's radio to use for testing. Is there a way I can hook these old speakers up to something to safely test them?
For the old speakers (like horns) we just used a nine volt battery and listened for a click. Often the old wires are bad so test right at the driver before you rule it bad.
If you're at home you can hook an audio source to it, but you'll probably need to do a little impedance matching depending on your audio source.
Use a spare output transformer. Connect the low impedance side to any 8 ohm speaker jack.
Thanks John and Sky. I'll try to post a couple of photos later. I don't really know anything about the 1920s stuff. I didn't want to do anything to damage them.
If they're in decent condition at all, the coil should be very high impedance and not easily damaged. They were dropping many times more than 9 volts in the original radio.
Not sure what he had in it but a man at the museum has an altoid can with headphone jacks on one side and the 1920's pin jacks on the other so he can test/listen to horns using his iphone, walkman, etc. so whatever he uses is small enough to fit into the altoid tin.
Need Help to ID this radio 11 tube Philco
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
My Philco 37-116 Restore
Thank you MrFixR55, I appreciate your comments very much. I do not detect much hum if any so I will be staying with the ...dconant — 05:15 PM
Hi DConant Yes, you can replace chokes with resistors.  You do stand the risk of increased hum.  the solution is to inc...MrFixr55 — 04:23 PM
There are currently 591 online users. [Complete List]
» 1 Member(s) | 590 Guest(s)
