philco 296 cap i.d.
i'm going thru this chassis,caps and resistors 1st. 2 questions;
part number 31,the value on schematic is .5mfd,the part number on the bakelite block crosses to a .05mfd,which is correct?
also,there is a large wire wound resistor about 5 inches long,what is it's value?
thanks,phil
See the Schematic Section right here on this site.
The Model 296 is there:
http://www.philcoradio.com/tech/images/296.jpg
Cap #31 is 0.5 uF. Plate bypass cap for the second 27 tube.
That wire-wound resistor is probably the BC resistor #44 in schematic.
Chuck
howdy and thanks chuck,p.# 44 is a tapped wire-wound and checks o.k.. the one i posted is not tapped and one side is grounded,other to filter block if i remember correctly,i'm at work,radio is at home. any other ideas?
i just looked at the schematic again,i only see one resistor to ground and the filter block,part #45 at 10k. i didn't think wire wounds were usually this high in value,do you see any other posibilities?
It's resistor #45 then, and yes, wire-wound resistors can be large values.
There are currently 1682 online users. [Complete List]
» 1 Member(s) | 1681 Guest(s)
