PT-41 short on the AM cycle
Recently bought one of these. Why did philco cut the AM band off at around 1600kc? Was there a good reason to do this?
Thanks
Chris
Originally the AM band only went to 1600 kHz. The expanded AM band we have had for a while now is a new allocation, once the old ham band was moved off that area to open for more commercial ventures. I'm sure some one else can give more specific dates.
Chuck
I don't believe the 160m HAM band has ever been lower than 1800/kc. From 1650 up to 1790/kc was the old police band and also used for LORAN around 1750/kc.
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
I was wondering if I could use a more common Philco speaker and just add the resistance I need for the coil and get a ne...dconant — 07:45 AM
There are currently 2381 online users. [Complete List]
» 2 Member(s) | 2379 Guest(s)
