Next on the list.
I scored a blone for the best price.. free. I had it on the variac today. The main PHilter can was getting hot. I'll be getting parts in the next few days. The CRT is good. [/img]
Visit the world's worst TV restoration website.
http://evilfurnaceman.tripod.com
O.K., Big Dave,
I'm curious...just what is a "blone"? Icon_smile
Assuming it's some sort of Philco TV, which model is it?
Sounds like the price was right...
It's like a "blone fuse," right? Icon_wink
Whoops, that should have been blonde. This is going to be a fun one. There are four or five couplates that I'll need to rebuild. The lytics got hot when I soft started it, but the CRT is good.
The model number is gone, but the chassis is a 9L42. I have service manuals (Tellaides) that will work with this one and also for my 14" Transitione portable.
I should be able to order parts soon.
Delco car radio Peko vibrator converstion issues
Rich, There is an Australian website (Cool386.com) that has much useful info regarding repair and restoration of vibr...Joe Rossi — 07:29 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
There are currently 2896 online users. [Complete List]
» 2 Member(s) | 2894 Guest(s)
