Philco 118 code 121 new project+question
Well, I said I was going to give up after finally finishing the 38-116 but my neighbor brought over a 118. Chassis doesn't look too bad, cabinet looks good, speaker should work with a cone! Sure is cramped underneath and with enough cap blocks to keep me busy. Open 1st IF primary, all other coils and iron look good on preliminary inspection. Posting for parts requirements on the classified. Though you would like to see a preview of the chassis bottom.
Jerry
[Image: http://i303.photobucket.com/albums/nn129...e001-9.jpg]
Thought I would ask for some ideas on the removal of the bad 1st IF transformer. Unlike other coils the IFs are not held in place in the can with a simple metal tab on the coil screwed to the chassis. The insides are locked in the can with a "C" clip that appears to be also sheathed in a cotton type covering. Actually looks like a piece of chassis wiring, but it is not. I see no way to reach in there and pop that clip out of the groove that it sets in. Anyone out there do this successfully? If so technique used please?
Thanks Jerry
Edit: got it out and repaired it!
Jerry
Philco 39-116 radio and remote
Hi Brad, Thanks so much for the info!  Do you happen to have the specs for the PT-86 transformer?  I did not find a lis...RichG — 04:32 PM
Philco 269 - 444 FIVE VALVE VERSION?
Thanks Arran; If your set has five tubes/valves then it could be an A537, V537, or a U527, then again it looks like s...ChasL0001 — 11:07 AM
Philco 29 or 45
29 chassis has a shadow meter while 45 chassis does not. Shadow meter is part no. 27 in the 29 schematic. compare it t...klondike98 — 10:32 AM
Sorry, Chas. Re the burns, I broke my first TV at the age of 3.  Between my electrical experiments :yikes: (My mom wa...MrFixr55 — 09:07 AM
Philco 41-221 Restored
Thanks for the compliment Richard. The tenite grille is original. A few of the horizontal slats were slightly warped so ...RodB — 08:44 AM
Philco 29 or 45
Hello, I have just received a Philco lowboy where the tube layout label in the cabinet says 29 or 45. There is no label ...dconant — 08:29 AM
Mr fixr, That is great news I would love to see repo grille !! I too have a very similar Philco but my cabinet has fab...radiorich — 08:22 AM
Hi Rod, I always tell people that my scars give me character.  :wink:   Great job on the radio.  Is the grille origi...MrFixr55 — 08:00 AM
It looks like the PENDD61 valve/tube must have failed, so someone replaced it with the EBC33, which is a double diode-tr...Arran — 04:29 AM
Hello Chas. Radiomuseum has information on both sets.  Thanks Gary, lots of good info there. Perhaps we'll ha...ChasL0001 — 02:23 AM
There are currently 1976 online users. [Complete List]
» 1 Member(s) | 1975 Guest(s)
