Well it has happened again, found another 38-116! That's two this summer! It is 100% complete and the cabinet is in good condition but has been stripped and some what refinished. The chassis is nice and complete with a full set of engraved base Philco tubes. The owner says he was not able to get any reception and I have not tried. The power cord is in BAD condition. Grand total for this one $100. Not to sure what to do with this one, didn't really need another one but could not pass it by.
Gregb
Gregb, at that price you have a lot of options. They are great radios and I'm certain someone within a local pickup area would return you a tidy profit. Super find and price. Post some pictures and you might excite some locals.
Jerry
Hi Jerry:
I will post a picture tonight but sad to say there are no locals near me, everyone goes to your part of the world. Its to cold here.
Gregb
Greg: Many fond memories of in my early years traveling through your area. I like the city, of course it was summer. Our house had a wood burning heater in the living room! Nice to make it toasty in the winter of which we don't have much. We replaced it with a pellet stove, easier to control and a lot less smoke coming out. I never mastered the stacking of the wood and the old one required a lot of attention, not to mention removing ash. I prefer the cold to the hot, which we are now in.
Good luck on finding a home for that nice radio.
Best, Jerry
Being the hoarder that I am, I will most likely keep it.
Gregb
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
There are currently 4830 online users. [Complete List]
» 2 Member(s) | 4828 Guest(s)
