Philco B314JWH TV
A Philco TV, though it's made in Taiwan for some company who must have bought the rights to the Philco trademark
(06-05-2015, 02:33 PM)wa2ise Wrote:  A Philco TV, though it's made in Taiwan for some company who must have bought the rights to the Philco trademark
 That may have been made after Philco was sold to GTE Sylvania by Ford, a lot of the lower end Philco products like  B&W TVs and Radios were "outsourced" to Taiwan around that time, Brand Z did the same to a large degree as well as to Mexico.
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
There are currently 3300 online users. [Complete List]
» 2 Member(s) | 3298 Guest(s)
