Emmett Till's family Philco TV set
Emmett Till was the kid killed in Mississippi in 1955.
[Image: https://static02.nyt.com/images/2016/08/...-jumbo.jpg]
Looks like the TV has a CBS channel 2 on. Likely in Chicago, not Mississippi, if what I find on the 'net is accurate...
The TV looks to be fairly new for 1955. People on other antique TV forums tell me it was a Philco from around 1952 or 53.
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
There are currently 5283 online users. [Complete List]
» 2 Member(s) | 5281 Guest(s)
