Another noob with another Philco!
https://sarsradio.com/index.htm
This is the Club in your area maybe zip them an email, maybe have a mbr with a tester?
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
There are currently 4024 online users. [Complete List]
» 1 Member(s) | 4023 Guest(s)
