Threads: 4
City: Hannibal
State, Province, Country: Missouri
I'll admit, I'm brand new to this and completely ignorant. I have a '59 Philco record player (G-1606) with the matching speaker (SA-1000). The record player plays great. The speaker, however, would only make an extremely loud, high pitched hum. I removed and repacked a multicapacitor (40/20/10 @ 350WV). The repack capacitors that I used were a little bigger mdf and voltage but everything I researched said that it would be fine. I replaced the old with the new and whala! now I have nothing but hiss in the speaker.
I've decided to replace ALL the capacitors but they are only labeled by mfd in the schematic and parts lists. What WV/VDC should I go with?
Threads: 266
Generally 630v caps are the easier to get. You may find the cap across the output transformer maybe higher in voltage. If so use two caps in series @ twice the capacitance to double the voltage rating.
Threads: 24
City: Edmonton AB CA
Sorry Terry, caps in series is half the capacitance and twice the voltage.
Threads: 266
Yes that is true but what I said was to double the capacitance.
" If so use two caps in series @ twice the capacitance"
So the capacitance divides and the voltage doubles in series if the capacitance is equal between the two caps.
(This post was last modified: 01-19-2019, 05:13 PM by
Radioroslyn.)
Threads: 24
Got it, sorry Terry
Gregb
