Next on the list.
I scored a blone for the best price.. free. I had it on the variac today. The main PHilter can was getting hot. I'll be getting parts in the next few days. The CRT is good. [/img]
Visit the world's worst TV restoration website.
http://evilfurnaceman.tripod.com
O.K., Big Dave,
I'm curious...just what is a "blone"? Icon_smile
Assuming it's some sort of Philco TV, which model is it?
Sounds like the price was right...
It's like a "blone fuse," right? Icon_wink
Whoops, that should have been blonde. This is going to be a fun one. There are four or five couplates that I'll need to rebuild. The lytics got hot when I soft started it, but the CRT is good.
The model number is gone, but the chassis is a 9L42. I have service manuals (Tellaides) that will work with this one and also for my 14" Transitione portable.
I should be able to order parts soon.
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
There are currently 3323 online users. [Complete List]
» 2 Member(s) | 3321 Guest(s)
