Modern console?
There is a Philco console TV locally. I imagine it's going to go cheaply, but I am curious to know anything about it at all. It appears to be the original owner selling as it is complete with all manuals.
Not concerned about value ...... just curious to know if service info is available and what sort of quality this would be, given that it's the typical mid-60's/'70's aircraft carrier type console?
cheers
SAMS was available in every single piece of TV equipment.
Philco Ford model 26C480 doesn't seem to be there. I'm not surprised. It's fairly new and Canadian.
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
There are currently 3816 online users. [Complete List]
» 3 Member(s) | 3813 Guest(s)
