Threads: 34
City: Fountain Hills, Arizona
Does anyone know where I might find an owners/operation manual for a Silvertone Model 1905?
What I am trying to understand is the function of the second dial hand on this radio. The main tuning hand or pointer obviously tracks across the tuning range; but, there is a second pointer that tracks around the dial multiple times as the radio is tuned from one end to the other.
What is its function?
Don
Threads: 407
City: Boston
I think you are referring to the Dual Condenser Drive Shaft, you can tune wide or narrow, pull/push tuning knob in or out to go wide or narrow.
[Image:
https://www.radiomuseum.org/images/schem...622202.png]
Schematic on Nostalgia may tell you all you need,
Paul Silvertone.......
Threads: 34
Paul,
I understand the dual ratio drive. What I specifically do not understand is the purpose of the additional pointer on the dial. It moves much faster than the tuning pointer and I can't figure our what its purpose is.
Don
Threads: 407
City: Boston
So on mine the Airplane pointer is wide tuning the half size pointer is fine.
Did I understand your query?
I love Silvertone, the chassis prefix tells you manufacturer.
Threads: 54
City: Lexington, KY
If I understand your question Zenith called that the second hand. It is used for fine tuning so you can relocate a station easier than the single tuning hand alone. It sounds like Silvertone used the same concept.
Threads: 407
City: Boston
Silvertone trying to be Zenith on Sears Roebuck terms, easy down payment or Sears charge account.
Threads: 34
Thanks, guys that makes sense.
Don
Threads: 407
City: Boston
From the Mark Stein Book on Silvertone it appears the set was manufactured by Air King in Brooklyn NYC.
