Noob question
Are wanted to buy posts allowed here?  I don't want to step on toes with my first post . . . . .  .
thanks
Art
Hi,
Wanted ads are most welcome...in the proper forum.
Please post your "Wanted" ads in the Wanted Ads forum here.
If you are on the Phorum home page, scroll down the page until you see the Trading Post section, which includes For Sale or Trade, Wanted Ads, Items For Sale Online and Swap Meets.
Thanks.
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
