Philco 49-909
Hello
I have my great grandmothers radio and was wondering if anyone had a copy of the owners manual for it?
David
Here's the service info for it. http://www.nostalgiaair.org/PagesByModel...013676.pdf
Yerry
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
There are currently 4020 online users. [Complete List]
» 1 Member(s) | 4019 Guest(s)
