Voltage draw on 40-185
I am restoring a 40-185; all the caps and rubber wiring has been replaced; the set has been aligned and plays well with only some minor audio distortion. I have checked the voltages on the tubes and discovered they are about 20 to 30 volts low. I have also found the RF Coupler #13 on the Riders is only reading .5 ohms and should be at 3.5. Would this cause my low voltage? Can I rewind the RF coupler, and if so how to do it and what wire size should is use? If this could not be causing my voltage draw, then what else should I look into.
Thanks
Skip
Hi Skip,
The RF coupler item # 13 will not cause your voltages to be low. Did you replace all the capacitors or just the filters? Make sure the polarity of the filter capacitors are correct. Check the voltage on the control grids of the output tubes, if high, it will cause the output tube to draw too much current and pull the voltage down. If that is the case look at capacitor # 46.
M R Radios   C M Tubes
Steve thanks for the heads up. I had replaced all the caps and double checked the ground on the e-caps. I did discover a cold solder and a bad new cap. I also discovered I had tied resister #49 to the ground at resister #59 instead of #60. Once i fixed those issues my voltages are right inline.
If I wanted to rewind #13 the RF coupler, what type of wire should I use? I have removed the wax coating and found the break in the wire, but it is so brittle that I can not splice it back together without breaking it in another spot. The radio plays with out the RF coupler in, on BC, have not really tried the SW bands yet, is the RF Coupler needed for the SW bands?
Skip
Philco 39-116 radio and remote
Hi Brad, Thanks so much for the info!  Do you happen to have the specs for the PT-86 transformer?  I did not find a lis...RichG — 04:32 PM
Philco 269 - 444 FIVE VALVE VERSION?
Thanks Arran; If your set has five tubes/valves then it could be an A537, V537, or a U527, then again it looks like s...ChasL0001 — 11:07 AM
Philco 29 or 45
29 chassis has a shadow meter while 45 chassis does not. Shadow meter is part no. 27 in the 29 schematic. compare it t...klondike98 — 10:32 AM
Sorry, Chas. Re the burns, I broke my first TV at the age of 3.  Between my electrical experiments :yikes: (My mom wa...MrFixr55 — 09:07 AM
Philco 41-221 Restored
Thanks for the compliment Richard. The tenite grille is original. A few of the horizontal slats were slightly warped so ...RodB — 08:44 AM
Philco 29 or 45
Hello, I have just received a Philco lowboy where the tube layout label in the cabinet says 29 or 45. There is no label ...dconant — 08:29 AM
Mr fixr, That is great news I would love to see repo grille !! I too have a very similar Philco but my cabinet has fab...radiorich — 08:22 AM
Hi Rod, I always tell people that my scars give me character.  :wink:   Great job on the radio.  Is the grille origi...MrFixr55 — 08:00 AM
It looks like the PENDD61 valve/tube must have failed, so someone replaced it with the EBC33, which is a double diode-tr...Arran — 04:29 AM
Hello Chas. Radiomuseum has information on both sets.  Thanks Gary, lots of good info there. Perhaps we'll ha...ChasL0001 — 02:23 AM
There are currently 1976 online users. [Complete List]
» 1 Member(s) | 1975 Guest(s)
