Phorum How-To #7: How Can I Change My Time Zone?
First, go to your User CP. Now, click or tap Edit Options under Your Profile.
[Image: https://philcoradio.com/images/phorum/Ph...07_001.jpg]
Look for the Date and Time Options section:
[Image: https://philcoradio.com/images/phorum/Ph...07_003.jpg]
Under "Date and Time Options," look for the text which reads "If you live in a time zone which differs to what this board is set at, you can select it from the list below."
The default time setting for the Phorum is US Eastern Time which is GMT -5:00.
To change it to your local time zone:
Click or tap the drop-down box labeled "GMT -5:00 (current time)" with a time setting, as shown below:
[Image: https://philcoradio.com/images/phorum/Ph...07_004.jpg]
From this drop-down box, select or tap the time zone where you live.
Hint - GMT -5:00 = Eastern Time Zone.
GMT -6:00 = Central Time Zone.
GMT -7:00 = Mountain Time Zone.
GMT -8:00 = Pacific Time Zone.
For Phorum members living outside the USA, you should be able to figure out the proper settings here.
Other Time Settings
While you are here, you can also change a few other settings if you wish to do so.
Date Format
If the date format is not to your liking, click or tap the drop-down box and change it from the system default to whatever you wish.
[Image: https://philcoradio.com/images/phorum/Ph...07_005.jpg]
Time Format
If the time format is not to your liking, click or tap the drop-down box and change it from the system default to whatever you wish.
[Image: https://philcoradio.com/images/phorum/Ph...07_006.jpg]
Finally, you may choose whether you want the system to compensate for Daylight Saving Time or not:
[Image: https://philcoradio.com/images/phorum/Ph...07_007.jpg]
Select or tap the DST setting you prefer in this drop-down box.
When you are finished, click or tap the "Update Options" button...and your settings will be saved.
Thanks, it worked
Joe
That one cannot be taken apart well. It is riveted. But the domed switch luckily has some spacing (not much and not inte...morzh — 09:44 PM
Hello Mike, that D5 is great for switches and I do the same I will try spraying it through a side hole first before tak...radiorich — 09:38 PM
Almost decided ot turn it on, but didn't like the power switch being 50 - 100 Ohms, so it is the same exact switch as in...morzh — 08:56 PM
Philco 49-1040
+1 Bob. Yeah, they bought it in 1949 or so, but by 1960, with the CRT starting to dim and after having the set repaired...MrFixr55 — 04:41 PM
Hi Richard. Yes, we are waiting for warm weather. I have more than a dozen hulls waiting to be painted.RadioSvit — 11:06 AM
Then it is even easier. Yep, my GE guide also says "Silicon".morzh — 09:43 AM
Mike, according to my ECG replacement guide, the AR107 & AR108 both cross reference to a ECG 123A as does a GE-10. T...462ron — 09:41 AM
The 66 Ohm filter in the 1st detector's plate circuit. Look in the early version sch. Here it is, the spiral that ma...morzh — 09:11 AM
Ron yes, that was found. The problem is trying to find GE-10 for AR107/108. I could not find even mentioning of it. ...morzh — 09:06 AM
Your output transistor X6 cross references to a GE-3 transistor and I’ve used that before. There are a few here on eBay…...462ron — 07:58 AM
There are currently 3760 online users. [Complete List]
» 1 Member(s) | 3759 Guest(s)
