41-300 = Happy Camper
49Stude63 Wrote:I had tried several times on ebay to purchase one of the these radios but seem to always end up as a dollar short on the bids, so I finally just gave up. I always thought they would be a decent sounding and a decent performing radio if restored.
I own a 41-315 which is the same chassis but a different cabinet and it is a great performing radio, excellent sensitivity and selectivity and a good sound from its big speaker also. The 41-295 is also almost identical in performance and those should be more common. If you know anyone in the Minneapolis area there is currently a 41-300 for sale on Craigslist.
Delco car radio Peko vibrator converstion issues
Rich, There is an Australian website (Cool386.com) that has much useful info regarding repair and restoration of vibr...Joe Rossi — 07:29 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
There are currently 4025 online users. [Complete List]
» 4 Member(s) | 4021 Guest(s)
AvatarAvatarAvatarAvatar
