Dial Apart on 34
Hi All;
I have downloaded The information on Dial and replacing the Rubber "O" rings, but I am not that far along.. I want to get the Dial face off, so I don't break or crack it..
Also I see that ther are three soldered screws under the Chassis for the Variable Capacitor, and Four screws for the mechanical gearing mechanism.. What all needs to come off and is it in any order or preference ?? and I need to take off the Vairable Capacitor to get at all of the Rust on the top of the chassis.. I would love to take the coil cans off as well, but I don't think they come off.. Am I right about that ?? The top of the Chassis has some deep rust stains in many places on the top of it..
Also, I did order the Tubes that I need.. Two of each, type..
THANK YOU Marty
Hi All;
I found out that the plastic dial face doesn't twist off like the other Dial faces, but it has two set screws that I did not see.. They were hidden from my sight, when I looked at it, they revealed themselves after taking off the front four screws and turning the Dial..
I now have the Variable Capacitor off and can clean the top of the chassis..
I also found out that the top of the IF cans can indeed come off from the top, as it has a large "C" clip holding it on..
Can it safely be taken off and still put back on and hold the can in place ??
THANK YOU Marty
Philco 39-116 radio and remote
Hi Brad, Thanks so much for the info!  Do you happen to have the specs for the PT-86 transformer?  I did not find a lis...RichG — 04:32 PM
Philco 269 - 444 FIVE VALVE VERSION?
Thanks Arran; If your set has five tubes/valves then it could be an A537, V537, or a U527, then again it looks like s...ChasL0001 — 11:07 AM
Philco 29 or 45
29 chassis has a shadow meter while 45 chassis does not. Shadow meter is part no. 27 in the 29 schematic. compare it t...klondike98 — 10:32 AM
Sorry, Chas. Re the burns, I broke my first TV at the age of 3.  Between my electrical experiments :yikes: (My mom wa...MrFixr55 — 09:07 AM
Philco 41-221 Restored
Thanks for the compliment Richard. The tenite grille is original. A few of the horizontal slats were slightly warped so ...RodB — 08:44 AM
Philco 29 or 45
Hello, I have just received a Philco lowboy where the tube layout label in the cabinet says 29 or 45. There is no label ...dconant — 08:29 AM
Mr fixr, That is great news I would love to see repo grille !! I too have a very similar Philco but my cabinet has fab...radiorich — 08:22 AM
Hi Rod, I always tell people that my scars give me character.  :wink:   Great job on the radio.  Is the grille origi...MrFixr55 — 08:00 AM
It looks like the PENDD61 valve/tube must have failed, so someone replaced it with the EBC33, which is a double diode-tr...Arran — 04:29 AM
Hello Chas. Radiomuseum has information on both sets.  Thanks Gary, lots of good info there. Perhaps we'll ha...ChasL0001 — 02:23 AM
There are currently 1977 online users. [Complete List]
» 1 Member(s) | 1976 Guest(s)
