Threads: 113
City: The Villages
I have two of these and there is no dial light in either and I can't find one in the schematic. Has anyone ever added one? Is it a good idea to do so?
Here's the schematic
Eric
The Villages, FL
Threads: 88
City: Tacoma
These weren't designed to have a dial light. If you were to add one, it would have to be a 120V type, as there is no rectifier tube from which to tap the voltage for a smaller bulb.
Threads: 113
City: The Villages
Thanks Brenda, that's kind of what I thought. I'll leave it the way it is.
Eric
The Villages, FL
Threads: 543
City: Jackson, NJ
Take a bright LED about 10mA or so. Take a resistor. Take a diode, some 50V Vr will do. Put them in series acrodd any of the 12V filament of one of the tubes.
The diode and the LED should be plugged with the same poalrity and the resistor should be about 1K to 2K.
Try it see how it works.
PS. Do not extract the tube whose filament you used for the LED while the radio is hot.
(This post was last modified: 03-31-2014, 08:51 PM by morzh.)
Threads: 88
City: Tacoma
Wouldn't even need the diode, Mike. LED's run fine on AC.
Threads: 18
Neon pilots complete with mounting stuff and resistor can be had for pennies. Bought a pack years ago and still have some. Use on 120 VAC, no heat, drill one hole and you're set.
Threads: 113
City: The Villages
Considering the fact that Zenith didn't want to put one in, I'm going to leave it the way it is.
Eric
The Villages, FL
Threads: 543
City: Jackson, NJ
Brenda
It may run fine but it is out of specs. If you have 6 to 12V AC across the LED and it is reversed then you are exceeding the max reverse voltage which for most LED lamps is 4-5V. Hence the diode.
(This post was last modified: 04-04-2014, 05:53 PM by morzh.)
Philco 39-116 radio and remote
Hi Brad,
Thanks so much for the info! Do you happen to have the specs for the PT-86 transformer? I did not find a lis...RichG — 04:32 PM |
Philco 269 - 444 FIVE VALVE VERSION?
Thanks Arran;
If your set has five tubes/valves then it could be an A537, V537, or a U527, then again it looks like s...ChasL0001 — 11:07 AM |
Philco 29 or 45
29 chassis has a shadow meter while 45 chassis does not. Shadow meter is part no. 27 in the 29 schematic. compare it t...klondike98 — 10:32 AM |
Sorry, Chas.
Re the burns, I broke my first TV at the age of 3. Between my electrical experiments :yikes: (My mom wa...MrFixr55 — 09:07 AM |
Philco 41-221 Restored
Thanks for the compliment Richard. The tenite grille is original. A few of the horizontal slats were slightly warped so ...RodB — 08:44 AM |
Philco 29 or 45
Hello, I have just received a Philco lowboy where the tube layout label in the cabinet says 29 or 45. There is no label ...dconant — 08:29 AM |
Mr fixr,
That is great news I would love to see repo grille !!
I too have a very similar Philco but my cabinet has fab...radiorich — 08:22 AM |
Hi Rod,
I always tell people that my scars give me character. :wink: Great job on the radio. Is the grille origi...MrFixr55 — 08:00 AM |
It looks like the PENDD61 valve/tube must have failed, so someone replaced it with the EBC33, which is a double diode-tr...Arran — 04:29 AM |
Hello Chas. Radiomuseum has information on both sets.
Thanks Gary, lots of good info there.
Perhaps we'll ha...ChasL0001 — 02:23 AM |
There are currently 1976 online users. [Complete List] » 1 Member(s) | 1975 Guest(s)
