Philco 46-1201 (127) Resistor Change
I noticed R100 A B from the original Chassis was changed to  80 ohms, for the Version 127. Mine checks out to be 101 Ohms.  This is Wire wound so I think maybe there is a misprint.   The  Part Number on the resistor is correct.
Thinking 100 ohms is correct value. Anyone run across this restoring a Version 127 ???
It is in the Filament string,so not really too fussy. Seeing my Line Voltage is 124 VAC.
I stand corrected the resistor is in the Cathode Circuit of the output tube.
Bob T
