Removing speakers
Awwww now, . . .  whatchu got against melting rubber insulation bud?   Icon_lol
Jake, melting rubber insulation, forsooth! LOL! I have actually encountered that. Rubber insulated wire where the rubber was turning into sticky goo. This seems especially a problem with the blue wire, although it can happen to other colors too. I don't know why. Usually though it just gets hard and brittle and crumbles off the wire.
Icon_e_wink
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
There are currently 3910 online users. [Complete List]
» 1 Member(s) | 3909 Guest(s)
