01-23-2012, 09:38 PM
I have recapped and changed resistors as required, installed a solid state vibrator and added new buffer cap. I have 212v at the rectifier. The manual oscillator coil was open, fixed that and the tuning condenser came to life. My problem is that I can only receive at 1570 kc and 1120kc at the same time and nothing else anywhere on the dial. When the presets are selected, nothing on the first 2 (580 to 1050kc) 3 is a weaker version of 4 and 5 (900 to 1580) which are loud and clear with 2 stations which sounds exactly like manual dial. The 1570 is a very strong local station. I noticed that the 2 station I receive are 455 kc apart. Alignment? The Philco sheet says to send 455kc thru .1mf cap to the antenna receptacle. I did that and the maximum output is where I have it, but no change in reception. I really like to figure as much of this kind of stuff out myself, but this beyond my diagnostic ability. Thanks for your thoughts
