Victor re57
  I am working on this Victor re57 and when I got it the wires to the motor were not connected.
  So far I have tried everywhere to get information about how these are hooked up  I have the RCA red book with clear schematics but it does not show or tell how the motor connects up.
    On the schematics it shows a 4.5mf cap connected in parallel with the motor.
   If anyone has information about this  please email me....  Thanks Dan walker
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
There are currently 5352 online users. [Complete List]
» 1 Member(s) | 5351 Guest(s)
