Threads: 24
City: Edmonton AB CA
I picked up a nice little model 54 and I was just having a look at it and it is a run 1 radio that has never been touched. It has all of the original engraved base Philco tubes and there is not one single repair anywhere on it. Does anyone need any pictures of a pristine original Philco 54 for reference before I start work on it?
Gregb
Threads: 551
City: Jackson, NJ
Even if no one right now needs it, makes sense for you to make as many pictures and notes as possible.
I have Kirk's chassis, not sure it is 54, could be 53 or 59, they are all similar.
Threads: 24
Yup, will do Mike. Thought I would offer if anyone was in need.
Gregb
Threads: 269
City: Bandon
State, Province, Country: OR
+1 on what mike said. nice clear photos of an original unit are priceless.
Threads: 212
City: Seattle
State, Province, Country: WA
I'd love to see those pictures too - and they would be a great resource for future restorers. The older these radios get the harder it is to find untouched examples.
Threads: 24
Threads: 551
City: Jackson, NJ
Yep. very clean too!
I have on of those from Kirk. Not sure which 5x it is but very similar. The two big wire resistors are not easy to forget.
I heard they are a b**ch to work on. Too crowded.
Threads: 269
City: Bandon
Thanks! Thats a nice clean chassis.
Threads: 212
City: Seattle
Beautiful - thanks for the pictures!
Threads: 11
City: Bellmawr, NJ
IF,,I remember right,,,Ron R. worked on something like this,,,,were he had to change out them coil resistors,,,
Threads: 269
City: Bandon
I think it was this 53C thread.
Threads: 24
Well the one good thing is I know everything is good because the radio works as is.
Gregb
(This post was last modified: 05-25-2016, 09:13 PM by gregb.)
Jackson 715 not working
Now that you posted the schematic, I don't know why that Sprague electrolytic cap is across the meter, as it is not indi...MrFixr55 — 05:51 PM |
What may be lacking in the PP Tube amps may be the 2nd harmonics, which some, especially RCA back in the day called &quo...MrFixr55 — 05:32 PM |
Usually in an emission tester, the tube under test is measured as if it were a diode. So, some testers connect all the g...RodB — 04:17 PM |
Restoring Philco 37-604C
Yep. F5 is green, D5 is Red.
Red is Bad.
Green is Clean.morzh — 01:30 PM |
I did start to do that but I stalled out because I could not figure out how the grid and plate get voltage. In this diag...daveone23 — 11:52 AM |
(Insert Homer Simpson "DOPF" Here.)
When all fails, look at the can. Took the Ron Ramirez advice, red Caig D...MrFixr55 — 09:23 AM |
Philco 91 Speaker Replacement
From your text I am not sure if you intend to use the existing speaker with a resistor instead of the field coil.
It wo...morzh — 08:44 AM |
My field coil is bad. I am still hoping to find an original, but if I can't I will go with a fitting Philco speaker, 125...dconant — 08:34 AM |
As Rod said, it is OK to use a fitting speaker, and then look for an original one.
If you buy a Hammond 125 output tr...morzh — 08:15 AM |
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM |
There are currently 3188 online users. [Complete List] » 2 Member(s) | 3186 Guest(s)
