Philco 37-610 knob
Just recieved it off ebay in one piece Icon_lol . In good shape except I need the tuning knob. The dual knob with the fine adjustment. Does anyone have one or know where to get one? I also seem to be missing the middle knob also. Any help would be appreciated.
http://radioatticarchives.com/images/p/P..._Malin.jpg
thanks
Chris
For excellent reproductions, there's Larry Bordonaro at Old-Time Replications.
http://www.antiqueradioknobs.com/
For good used knobs, here are two sources.
Mike Koste - gokmike AT gmail dot com
David Frush - parts2many AT aol dot com
Ron,
Thanks, I forgot about David. I have dealt with him before.
Chris
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
There are currently 5048 online users. [Complete List]
» 2 Member(s) | 5046 Guest(s)
