Stupid Q Did the Brit or Canadian sets
Use metric hardware? Have never had one.
The Brits used Whitworth years ago. We bikers run into the problem with old English motorcycles like BSA and Triumph... It is different from SAE and is not metric either.
Whitworth wrenches are marked the size of the bolt they fit not the size of of bolt head or nut. Plus the head size is in tenths of a inch. Thread pitch is 55 vs 60 for sae. I still have a set of whitworth tools just have not found anybody that I dislike enough to leave them to in my will! Stay safe David
Metric came into legislated use in Canada in the early 1980's. Before that we used the same system as was used in the U.S.A.
Up until around 1938, most of the chassis that went into Philco (UK) sets were made in Philadelphia and then sent over to Perivale.
I've owned as many as four British Philcos at one time (now down to two) and had no issues with hardware. Ditto the Canadian Philcos that have passed through here.
The only difference in hardware between Canadian and U.S built Philco sets is that the Canadian sets may have used Robertson socket head screws in the cabinets, since the cabinets wee often made by outside firms, the chassis hardware is the same as the U.S ones mostly, meaning hex heads.
Philco 39-116 radio and remote
Hi Brad, Thanks so much for the info!  Do you happen to have the specs for the PT-86 transformer?  I did not find a lis...RichG — 04:32 PM
Philco 269 - 444 FIVE VALVE VERSION?
Thanks Arran; If your set has five tubes/valves then it could be an A537, V537, or a U527, then again it looks like s...ChasL0001 — 11:07 AM
Philco 29 or 45
29 chassis has a shadow meter while 45 chassis does not. Shadow meter is part no. 27 in the 29 schematic. compare it t...klondike98 — 10:32 AM
Sorry, Chas. Re the burns, I broke my first TV at the age of 3.  Between my electrical experiments :yikes: (My mom wa...MrFixr55 — 09:07 AM
Philco 41-221 Restored
Thanks for the compliment Richard. The tenite grille is original. A few of the horizontal slats were slightly warped so ...RodB — 08:44 AM
Philco 29 or 45
Hello, I have just received a Philco lowboy where the tube layout label in the cabinet says 29 or 45. There is no label ...dconant — 08:29 AM
Mr fixr, That is great news I would love to see repo grille !! I too have a very similar Philco but my cabinet has fab...radiorich — 08:22 AM
Hi Rod, I always tell people that my scars give me character.  :wink:   Great job on the radio.  Is the grille origi...MrFixr55 — 08:00 AM
It looks like the PENDD61 valve/tube must have failed, so someone replaced it with the EBC33, which is a double diode-tr...Arran — 04:29 AM
Hello Chas. Radiomuseum has information on both sets.  Thanks Gary, lots of good info there. Perhaps we'll ha...ChasL0001 — 02:23 AM
There are currently 1976 online users. [Complete List]
» 1 Member(s) | 1975 Guest(s)
