Threads: 5
City: Danvers
State, Province, Country: MA
Hello, Im a rookie at this.I looked over the chassis and fixed a couple of connections. The tone control is cooked, it has .01uf and .015uf in the switch. Can I replace it with a .01uf 400 volts and a .022uf 400 volts? Also the speaker cone is in bad shape. Any help is appreciated. Thanks Ralph
Threads: 266
Hi and welcome,
You can but I would up the voltage rating to 630v. The .022 will make it sound a bit more muffled than the .015. As for the speaker you send it down to Sound Remedy in NJ. They can fix you up for a reasonable price. Or You can diy it if you can get the proper cone and center it.
Threads: 35
City: Roseville, MN
Hi Ralph, welcome. Terry is right about the .022 making the sound muffled. They are bypassing higher frequencies from the output transformer. But it depends on the speaker among other factors. I would use two .01 caps instead and definitely 630 volts.
Threads: 5
City: Danvers
Thank you for the welcome and information. Im sure I will have more questions as they arise.
Threads: 5
City: Danvers
Another question, the only cap I can get locally today is .01uf and 1000v. Would that work? Or should I be patient and order the correct ones?
Threads: 530
City: Jackson, NJ
Yes, The higher voltage is always OK.
